  • Darwin Castro Friend
    #184262
    Hi Guys,
    I’m trying to get a small script live help within the .. / templates / ja_mero / index.php and the script works correctly.
    The problem I have is that the search bar gets smaller and almost invisible.
    I’m putting the script at the beginning of the file.
    <! – BEGIN CODE TAG FUSION – DO NOT EDIT! -> <div Id=”swifttagcontainerw1kfdxc4g0″> <div id=”proactivechatcontainerw1kfdxc4g0″> </ div> <div style=”display: inline;” id=”swifttagdatacontainerw1kfdxc4g0″> </ div> </ div> <script type = “text / javascript”> var swiftrandom = Math.floor (Math.random () * 1001); swiftuniqueid var = “w1kfdxc4g0” var FUSION TAG END CODE – DO NOT EDIT! ->
    <? Php
    / / No direct access
    defined (‘_JEXEC’) or die;
    / / Check if plugin is jat3v3 Existed
    if (defined (‘T3V3’)) {
    throw new Exception (JText :: _ (‘T3V3_MISSING_T3V3_PLUGIN’));
    $ T3v3 = T3V3 :: getApp ($ this);
    / / Get configured layout
    $ Layout = $ t3v3-> getLayout ();
    $ T3v3-> loadLayout ($ layout);
    1. yoo386
    Stork11 Friend
    #480853
    Hello yoo386,
    I think you put the code in incorrect place. The code should be placed in “/templates/ja_brisk/tpls/default.php” and “/templates/ja_brisk/tpls/home.php” files, after “<body>” opening tag.
    Regards.
This topic contains 2 replies, has 2 voices, and was last updated by  Stork11 11 years, 10 months ago.
