doorknob Friend
doorknob
- December 2013
- 20 times in 1 posts
December 20, 2013 at 3:56 am #193119When I upgraded my test site to J3.2.1, I noticed that the search box has a ‘0’ immediately underneath it (see attachment). This had not been the case with J3.2.0.
I rolled back just the search module to J3.2.0 but the problem remained.
I inspected the module code and found nothing that could be causing the problem.
I went to the Joomla formum and found that someone else had also encountered the same problem and reported it as a new bug introduced in J3.2.1. The response on the forum was to suggest that they test with the Protostar template. I did that and found that the problem doesn’t occur with that template.
This suggests that the problem is being caused by a JavaScript process triggered by T3.Regards
PhilUsing T3 v2.0.1
T3 Bs3 Blank v 2.0.0This is fixed in T3 v2.0.2
- November 2014
- 3854 times in 3563 posts
December 23, 2013 at 8:15 am #516237The problem will be fixed in next version JAT3 framework but you can temporary fix it with my solution
Open plugins/system/t3/base/html/mod_search/default.php file
Change
if ($button) :
if ($imagebutton) :
$button = ' <input type="image" value="' . $button_text . '" class="button' . $moduleclass_sfx.'" src="' . $img . '" onclick="this.form.searchword.focus();"/>';
else :
$button = ' <button class="button' . $moduleclass_sfx . ' btn btn-primary" onclick="this.form.searchword.focus();">' . $button_text . '</button>';
endif;
endif;To
if ($button) :
if ($imagebutton) :
else :
endif;
else :
$button = '';
endif;doorknob Frienddoorknob
- December 2013
December 23, 2013 at 12:50 pm #516296This seems to be already fixed in T3 v2.0.2 or am I missing something?
- November 2014
AuthorPostsViewing 4 posts - 1 through 4 (of 4 total)This topic contains 4 replies, has 2 voices, and was last updated by Ninja Lead 10 years, 11 months ago.
Problem with search box in J3.2.1
