June 18, 2008 at 12:36 pm #129822
Joomla 1.5.3
Search doesn’t work 🙁
When I input any searching word, I get back to the main page with no results.
Login and registration works correctly.Here’s address of test installation http://www.barlew.pl
Language is Polish but it isn’t dificult to find Search (upper-right corner) “SEARCH” = “Szukaj”
Can anybody help?
Thank you!Best regards,
Barlewbennitos Friendbennitos
- May 2008
- 474 times in 407 posts
June 18, 2008 at 3:24 pm #254433Are your search plugins enabled?
—>[Plugins] and there the search plugins?
June 18, 2008 at 3:50 pm #254439Unfortuantelly yes 🙁
I’ve enabled all of them.Additionally, I’ve put ‘Search’ into user menu, so I can now call it, but still receive no results.
Any ideas? Maybe SEF enabled messing up here? However, the problem is still even when SEF is switched off 🙁
Thank you for any advise!
Best regards,
BarlewJune 19, 2008 at 9:07 am #254615Really nobody can help???
🙁I’ve noticed another problem – Spotlight module doesn’t show images and what’s more, when is enabled, texts disapear from images Featured news (mod_ja_catslwi ) – then I can see only pics with no any texts on them.
Please help: http://www.barlew.pl
Thank you!
UPDATE: I’ve installed a module for tags clouding and… I’m really suprised 🙂 When I click on any tag, I’m receiving search results for this word!!! It means that searching works correctly but there is still a question why I can use it in regular way from menu…
questbg Friendquestbg
- May 2008
- 339 times in 197 posts
June 19, 2008 at 1:57 pm #254669Hi Barlew
I really wish I could help you, but this is WAY beyond my abilities!
I checked your site and performed about 20-25 searches (some in English ‘Nokia’ etc., and some in Polish by copying content from your articles), always, I got no returns, but only front page again?
I’m really sorry I can’t help, but maybe this reply will push you to the top of the list again and somebody might know how to fix!!
😉This must be language related maybe? I’m using the same (Teline II, Joomla 1.5.3) but in English, and my site seems to work OK with the search?
Good luck, I hope somebody can help you more than I can!
Sherlock FriendSherlock
- 2478 times in 2162 posts
June 20, 2008 at 7:53 am #254891Hi.
i have viewed your site, and i saw that seem you changed something
Can you say what did you change ?June 20, 2008 at 6:09 pm #255023Hi nguoiabcd!
Yes, I made some changes according to advise by VisiGod.
Here is the list of themThank you!
Best regards,
BarlewSherlock FriendSherlock
June 21, 2008 at 4:07 am #255118hi
Before you change, did your site have that problem ?June 21, 2008 at 7:42 am #255139Hi!
I don’t know unfortunatelly. I had other problems which were fixed by those changes. I didn’t check “Search” before. Do you suggest to restore original settings in changed files?
Best regards,
Barlew -
This topic contains 9 replies, has 4 voices, and was last updated by barlew 16 years, 5 months ago.
