Tech-xml Friend
Tech-xml
- October 2010
- 5 times in 2 posts
May 11, 2016 at 2:29 am #929200Looking at my site with Google Webmaster tools in section: Words Content Key. I see that it is indexing of exorbitantly words: Detail, details
I wonder how to solve it, whether to block some of the robots.txt file or make any changes in Joomla?
pavit Moderatorpavit
May 11, 2016 at 5:59 am #929277Hi
You can avoid robots.txt file to index your content from Global configuration -> Site tab -> Metadata Settings section ->Robots
Or you can set each article to not be indexed setting the robot to no index from publishing tab.In any case i want to specify that this is Joomla core settings and has nothing to do with the template Ja Teline V.
Best regards
Tech-xml FriendTech-xml
- October 2010
May 11, 2016 at 12:55 pm #929418This reply has been marked as private.Tech-xml FriendTech-xml
- October 2010
May 12, 2016 at 5:41 pm #930026I solved the problem, but do not know if it’s the proper way and will have some consequence.
Part of the HTML which generates the problem is this:
<Dt class = "article-info-term">The module responsible for generating the word detail is:
mod_articles_categoryThe language file containing the word details:
en-BR.com_content.ini
COM_CONTENT_ARTICLE_INFO = "Details"My solution:
I edited the language file for:
COM_CONTENT_ARTICLE_INFO = ""Now the word detail no longer appears on the content of articles
AuthorPostsViewing 4 posts - 1 through 4 (of 4 total)This topic contains 3 replies, has 2 voices, and was last updated by Tech-xml 8 years, 7 months ago.
