May 25, 2017 at 11:11 pm #1037115
I had a double problem with the template JA Teline V: First I tried installing Artio Joomsef for SEO, and I did not display the articles in the categories. Now I bought the sh404SEF, and I unconfigure the modules I attached in the image. They must go vertical, but it changes me horizontally, next to each other. Disabling the sh404SEF normalizes everything.
The site I have offline so I do not index Google, as I am designing and testing
He tenido doble problema con la plantilla JA Teline V: Primero probé instalando Artio Joomsef para el SEO, y no me desplegaba los artículos de las categorías. Ahora compré el sh404SEF, y me desconfigura los módulos que adjunto en la imagen. Deben ir verticales, pero me cambia a horizontales, uno junto al otro. Al desactivar el sh404SEF se normaliza todo.
El sitio lo tengo fuera de linea para que no me lo indexe google, pues lo estoy diseñando y haciendo pruebas
Saguaros ModeratorSaguaros
May 29, 2017 at 2:46 am #1037623Hi,
I’m not entirely of your question here as I don’t see the difference in your screenshot. Could you clarify it in more details or send screenshot of how you want it should be?
AuthorPostsViewing 2 posts - 1 through 2 (of 2 total)This topic contains 1 reply, has 2 voices, and was last updated by Saguaros 7 years, 7 months ago.
Problem with SEO Plugin (Joomsef and sh404SEF) with JA Teline V
