Tech-xml Friend
Tech-xml
- October 2010
- 5 times in 2 posts
August 27, 2016 at 4:05 pm #963390It is possible to make changes to the template so that the SEO rastrei the H1 tag title?
I’m having low on my SEO because of this problem
August 29, 2016 at 1:48 am #963578Hi
Kindly give me the info on which part of the site you would like to add the H1 tags . I will help you to implement this on site .Tech-xml FriendTech-xml
- October 2010
August 29, 2016 at 1:06 pm #963790Article Joomla has a title H1 using the following HTML tags:
<H1 class = "article-title" itemprop = "headline"> </ H1>
My question is: You must have an H1 header in the article content to solve this problem?
If yes, how to solve this? The way I understand it, is not consistent to have two equal titles in the same article.Pankaj Sharma ModeratorPankaj Sharma
August 30, 2016 at 12:46 am #964037Hi , usually on article page article title has an H1 tag for its title , i am not sure for using h1 tag in article content , you can check it with your SEO team member and let me know if you want to modify the H1 title of articles.
AuthorPostsViewing 4 posts - 1 through 4 (of 4 total)This topic contains 3 replies, has 2 voices, and was last updated by Pankaj Sharma 8 years, 3 months ago.
Problem with SEO related H1
