October 25, 2012 at 12:54 am #181685
Hi, i just installed a sh404sef plugin, and it is causing some king of conflick with my home page layout.
Please help me Ja staff, because i really want to use the sh404sef plugin.
Stork11 FriendStork11
- March 2011
- 431 times in 393 posts
October 25, 2012 at 8:55 am #471070Hello bakeaboo,
I have checked and could not see any issue as reported. Please re-check and confirm the same.
Regards.
October 25, 2012 at 3:25 pm #471108You couldnt see any issue because i desactivated the plugin, i just activated it again, please check my site.
- March 2011
October 27, 2012 at 7:56 am #471246Hello bakeaboo,
Please update this patch into “/templates/ja_lens/js/wall.js” file.
Hope this helps.
Regards.
2 users say Thank You to Stork11 for this useful post
October 29, 2012 at 2:36 pm #471392Thank you! it worked!
December 19, 2012 at 9:55 pm #476829Hi, Stork11, can you do the same fo JA ZITE ? I want this patch, I have the same problem, I need help please
- March 2011
December 20, 2012 at 2:05 am #476842<em>@ghailan 351382 wrote:</em><blockquote>Hi, Stork11, can you do the same fo JA ZITE ? I want this patch, I have the same problem, I need help please</blockquote>
Hello ghailan,Can you describe your problem more details? If possible, would you mind getting me a few screenshots for more clarifications? Then I shall know what you are trying to achieve. Right now, I am quite not sure where to start.
Regards.
AuthorPostsViewing 7 posts - 1 through 7 (of 7 total)This topic contains 7 replies, has 3 voices, and was last updated by Stork11 11 years, 9 months ago.
Problem with sh404sef plugin, help please
