April 15, 2014 at 5:55 pm #196785
I installed the template with sample data and do not appear in the shop menu appears only 404 page.
You can help me?
Thank you very much.
Juan Carlos
TomC ModeratorTomC
- October 2014
- 3155 times in 2495 posts
April 15, 2014 at 6:08 pm #531001I just brought up your site and it looked fine to me
Is there a particular menu link which results in a 404 page?
April 15, 2014 at 7:57 pm #531016Yes, any submenu of menu shop … :'(
thanks!
TomC ModeratorTomC
- October 2014
April 15, 2014 at 8:11 pm #531018<em>@irentxun 421902 wrote:</em><blockquote>Yes, any submenu of menu shop … :'(
thanks!</blockquote>
The login information you provided is not working – please check username/password
April 15, 2014 at 8:18 pm #531019is already working …sorry!
thanks!
TomC ModeratorTomC
- October 2014
April 15, 2014 at 8:20 pm #531020<em>@irentxun 421906 wrote:</em><blockquote>is already working …sorry!
Glad you were able to sort it out . . . . All the best with your continuing site development.
April 15, 2014 at 8:24 pm #531023NO!! The problem continue!!!
Please!! help me!!
Nazario A FriendNazario A
- April 2013
- 284 times in 263 posts
April 17, 2014 at 8:39 am #531236@ irentxun,
The error comes when enable “Search Engine Friendly URLs” in Global Configuration.
Sometime it happen when your hosting provider not activate apache mod_rewrite for security reason. ask them fix this problem if still.
Two things to check:
1. Open the configuration.php file and look for this line:
public $live_site = ”;
Change this to read:
public $live_site = ‘http://bellaraejewelry.com/joomla/’;
Remember to remove this or change it when you move the site to the main directory
2. If that doesn’t work, open the .htaccess file (which as Laurie mentioned would have originally been named htaccess.txt) and look for the line:
# RewriteBase /
Change this to:
RewriteBase /joomla
Note that in my version there is no #
Upload the changed file(s) to the server and cross your fingers.
This topic contains 8 replies, has 3 voices, and was last updated by Nazario A 10 years, 7 months ago.
