Viewing 2 posts - 16 through 17 (of 17 total)
  • bvneck Friend
    #366132
    Hello, i just wanted to tell everybody that I had the same problem (white rectangle over shopping cart) and I solved it by turning off Ajax in the shop configuration as described in the VM Forum here
    Changing the minicart.tpl.php didn’t solve the problem, btw.
    rainfire Friend
    #379834
    <em>@zoga 104788 wrote:</em><blockquote>Hello, I have the same problem, and I try to solved with changing the file minicart.tpl.php with the one fixed, but nothin change. Fire fox continue to present the blank spot in my cart. The problem come just when I add the products, if I continue with the shopping the blank spot dissapear.
    Some new solution?</blockquote>
    This fix also didn’t work for me. I did find a fix that worked with Ajax Cart in the Virtuemart.net forums. Hope it works for you.
    http://forum.virtuemart.net/index.php?topic=49950.msg222457#msg222457
This topic contains 17 replies, has 7 voices, and was last updated by  rainfire 13 years, 10 months ago.
