March 21, 2008 at 7:24 am #126797
I have problem with showing more articles on the homepage.
Website URL: http://www.joomlabay.com
When you click on the links above the banner (page # 2, 3, 4, 5 or next) the articles are not displaying.
Any suggestion?
Michael
beastmode54 JA JobBoardbeastmode54
- November 2007
- 20 times in 1 posts
March 21, 2008 at 12:05 pm #242776Just wondering on your font page component…(the first item in your main menu) what do you have set for the number of articles….you should be able to set to the number that you desire.
March 21, 2008 at 2:22 pm #242781Yes, I know I can set the number of articles that can be appeared on frontpage. But I wont be able to see anything if I click on next page or page 2, 3, 4, 5 … etc.
March 21, 2008 at 2:48 pm #242782I got exactly the same problem, in main menu I have set the numbers i want to see on the frontpage 10 news posts and till that point its working good but when you click on next or 1, 2, etc you will get a empty page not showing the other news posts.
- November 2007
March 21, 2008 at 3:39 pm #242790I notices when u click the next button , on the next page the url has an addition that says limit 5….i dont think ive seen that before.
March 21, 2008 at 3:58 pm #242791I believe this mean 5 articles per page. If you set more than 10 articles, the articles will be displayed in 3 pages.
Obviously, the articles are not displaying when you click page 2, 3 or next page. And other users have the same problem too.
- November 2007
March 21, 2008 at 5:07 pm #242798I tested mine..and it worked fine….i used intro, instead on leading here are my settings
# Leading 0
# Intro 6
Columns 2
# Links 0Everything is on the frontpage…but i changes it to 4 on the front…and the other 2 diplayed fine on the second page
March 21, 2008 at 5:28 pm #242801that works. Thank you for your help.
Have a great day
March 21, 2008 at 6:01 pm #242802it indeeds works but its not a real solution just a work around, would be nice to see this fixed so it works as with other templates.
- November 2007
March 21, 2008 at 6:14 pm #242804your welcome…i think there is an older post that deals with the 2nd column layout. There is a fix for that……this issue may be related.
This topic contains 10 replies, has 3 voices, and was last updated by beastmode54 16 years, 9 months ago.
