  • brenot Friend
    #192444
    Hi, I have this site running at JA BRISK, and I love this template
    BUT, i Have some litte issues
    this one is about SIDEBAR-2 position, there is an issue that is moving this position to the bottom of the content…
    how ever, SIDEBAR-2 should be at the RIGHT..
    I´m sending a layout how it is, and how SHOULD BE.
    you can see the runnig wbesite at;
    http://192.185.164.91/~harasmhc/_novo2/index.php?option=com_breezingforms&view=form&Itemid=478
    1. Contato
    2. Contato_HOW_SHOULD_BE
    TomC Moderator
    #513038
    It looks like it may be an issue with the width of your column(s) in the layout.
    Might you be able to provide temporary access to your site admin so I can check it out?
    You can PM me the info if you like.
    Ninja Lead Moderator
    #513117
    @brenot: The problem on your site is from custom.css file
    Pls try to open it templates/ja_brisk/css/custom.css, look for this code:
    From
    #ja-content.span8 {
    width: 700px;
    Change to
    #ja-content.span8 {
    /*width: 700px;*/
This topic contains 3 replies, has 3 voices, and was last updated by  Ninja Lead 11 years, 1 month ago.
