  • marcossonotec Friend
    #1016418
    My problem can certainly be many that is using Ja Builder, it happens that it was with the layout of blog broken, hence looking in the forum I found the solution changing the <div class = "jub-block mainbody"> this was good But when I insert the link read more the block of the sidebar is sent down the article and if I change the sidebar side to the left and put the link read more the sidebar moves the content down. I’m leaving p print just below.
    1. img-1
    2. img-2
    3. img-3
    You can share the Admin login info of your site so I will take a look.
This topic contains 1 reply, has 2 voices, and was last updated by  Saguaros 7 years, 8 months ago.
