test melih
 melih
  • edd Friend
    #195847
    Hi there,
    I have changed the web site picture background and when I try to send an article by email to a friend (using the button send by email or print) it is using the same background that the web site.
    So I would like to know where in the CSS code can I change the backgraound for the “send to a friend” option.
    Thanks a lot for help 🙂
    ED
    chavan Friend
    #526958
    can you please post your site Url. so we can check the exact fix and suggest you
    chavan Friend
    #526988
    Go to this code: /templates/ja_bistro/css/template.css
    1. Add Background Image
    Add this code, upload your image to this folder /templates/ja_bistro/images/ and
    change the #22717f to any color code
    .com_mailto {
    background: url(../images/yourimage.png) no-repeat #22717f !important;
    2. Add background color
    Add this code, change the #22717f to any color code
    .com_mailto {
    background: #22717f !important;
    edd Friend
    #526990
    Hi there,
    Thanks a lot, it is working just fine.
    ED
This topic contains 4 replies, has 2 voices, and was last updated by  edd 10 years, 10 months ago.
