  • glucosillo Friend
    #195238
    Hello, I have a problem with the Ja Slideshow module on JA minisite. In several browsers, the page looks well (IE10, mozilla, Chrome).
    But in Explorer 8, I dont see the images or the messages on Slideshow (see images)
    I know that Explorer 8 is an old version, but some of my customers still uses this old version and cannot upgrade (problems with a different software)
    Do yo know any way to solve this (without upgrade IE I mean)?
    thanks
    1. explorer8
    2. explorer10
    I see some JS errors when viewing your site in IE8: http://prntscr.com/2w7lmq, please try going to backend > template manager > and disable Optimize JS option. This will help to know which file caused these issues.
    glucosillo Friend
    #524770
    Solved. I have disabled the mentioned field and now I can see the slider on IE8 also.
    Thanks a lot
    Glad it’s solved.
This topic contains 4 replies, has 2 voices, and was last updated by  Saguaros 10 years, 9 months ago.
