  • Pankaj Sharma Moderator
    #1085412
    I checked your site and but the image is showing fine on your site. Here http://prntscr.com/hxftoc Do you want to enable autoplay option in the slideshow? Regards
    tscharly Friend
    #1085475
    Hello Mr. Sharma,
    I would like to activate the autoplay option in the slideshow, where can I activate it.
    I have read the documentation several times but have not seen any setting of the autoplay function.
    Kind regards
    Karl
    #1085483
    Apply my suggestion given here to make the slideshow autoplay.
    tscharly Friend
    #1085608
    I have changed the setting but unfortunately without success, under the style gallery setting the slideshow works without problems but under style-owl it does not work.
    abstract of the style-owl file:
    (function($){
    jQuery(document).ready(function($) {
    $(“#acm-slideshow-id; ?> .owl-carousel”).owlCarousel({
    addClassActive: true,
    items: 1,
    loop: true,
    dots: true,
    dotsEach: true,
    merge: false,
    mergeFit: true,
    nav: false,
    slideBy: 1,
    autoPlay: 12000
    #1085664
    Use the autoplay as below
    autoplay: 12000
    tscharly Friend
    #1085871
    Thank you for having so much patience with me, it works now.
    Many Thanks
    Greetings and thanks
    Karl
    #1085922
    You are welcome!
This topic contains 7 replies, has 2 voices, and was last updated by  Pankaj Sharma 6 years, 11 months ago.
The topic ‘Problem with Slideshow’ is closed to new replies.
