  • joserra57 Friend
    #178837
    Hello
    I’m using the template JA TRAVEL my webpage is http://www.vacacionesenasia.com and i have a proble with slideshow module
    I have 2 pictures that its have dissapearead but its properly placed into the server
    What’s wrong with these pictures?
    I put hte pictures in the server with this names
    And i put its in 2 position
    images->residez->images->stories->slideshow
    please i need help
    Joserra
    PD, sorry for my english
    Hi joserra57,
    You only need to add image in images/stories/slideshow if you choose to show images in slideshow from this folder. It will create automatically images in resized images folder. Please try to remove images in resized image folder and disable cache in advanced settings of this module, also clear T3 cache and let me know what’s going on.
    joserra57 Friend
    #460358
    Hello Saguaros
    I have done everything you told me, I deleted the images I’ve cleared the cache and the cache module desabilidato and still see only the 2 images
    if you want i can send a user and pas for you look the situation
    I wait yours news
    Joserra
    joserra57 Friend
    #460379
    Hello Saguaros
    It happens something strange, resized, after having deleted the images, reappears me another photo that is seen in the picture
    I put a picture of Fillezilla
    1. rezided
    2. stories
    joserra57 Friend
    #460381
    Hello Saguaros
    I change the name for images , begin in SL-2 and finished in sl-5 and apear 3 images, but reeading the firebug i look that not apear the images numer 4
    I put the code
    1. html-slideshow-asia
    TomC Moderator
    #460383
    I’m currently seeing 3 of your 4 slides …. with slide #3 missing
    Are you able to provide a screen-capture of your slideshow configuration settings?
    joserra57 Friend
    #460476
    Sorry
    I put a picture about my slideshow module
    1. slideshow
    Please check the image path in article that don’t show image in slideshow. If it’s correct, PM me admin and FTP account? I shall check this for you
    Hi joserra again,
    I figured out! The cause is that in article you should include
    <!– {jaimage main=”images/stories/slideshow/sl-2.jpg” thumb=”images/stories/slideshow/sl-02-thumb.jpg”} –>
    inside article you wanna display in slideshow. In your case, I open article: Indonesia Aventura > click ‘ and add above jaimage in the end of article. Please change to your desired image path.
    About problem of images folder, you can follow this guide of JA Slideshow module:
    http://www.joomlart.com/forums/topic/ja-slideshow-module-userguide/
    And let me know if you need further help.
    joserra57 Friend
    #460834
    Your solution iis correct
This topic contains 10 replies, has 3 voices, and was last updated by  joserra57 12 years, 4 months ago.
