  • vivaldo moscatelli Friend
    #1071734
    Hi all,
    I’m experiencing a problem with the slideshow:
    Here http://www.geo-costruzioni.it/sito/index.php I have problem with the 4 slides: I just can see the first two fine then problem displaying the others.
    Can you please help?
    Pankaj Sharma Moderator
    #1071783
    Kindly share the site super user details in Private reply.
    #1071972
    #1072022
    I re configured the slideshow module and its showing all the 4 slides fine.
    Kindly check the site.
    #1072290
    Hi PanKaj
    thanks for the mask on slideshow… Still have the problem with the third slide and fourth: in chrome see the image but no text, in ie can’t see the slide even…
    Thanks for your help
    Vivaldo
    #1072506
    You added two slideshow module on the same page that is creating conflict with classes. kindly disable the one slideshow module and check this issue again.
This topic contains 5 replies, has 2 voices, and was last updated by  Pankaj Sharma 7 years, 2 months ago.
