  • yudhizth Friend
    #200628
    Please help me to fix this problem, I try to customize slideshow module, but instead an error. The slider was dissapear when I change text of Slideshow.
    Before
    After
    1. slideshow1
    2. slideshow2
    Pankaj Sharma Moderator
    #546527
    can you please share the site url
    . and PM me admin details of your site . I will have a closer look .
    cweh Friend
    #548091
    you had to turn the wysiwyg editor off, than copy the code again and it will work….. dont know why, but it works 🙂
    #548122
    <em>@cweh 443983 wrote:</em><blockquote>you had to turn the wysiwyg editor off, than copy the code again and it will work….. dont know why, but it works :)</blockquote>
    Hi Actually when you added the code into editor and toggle the view , the editor will remove the code . so whenever you adding a code Go to Global configuration >>default editor>>NONE .
    then open module and add code , save it .
    after that you can set the default editor from global config. again
This topic contains 4 replies, has 3 voices, and was last updated by  Pankaj Sharma 10 years, 4 months ago.
