February 4, 2009 at 2:11 pm #137785
Hello, new boy @ Town 🙂
I have installed the template and start playing around. i have one problem with slideshow.
First of all, the modules positions Topsl1 and Topsl2 are bond to each other? I mean if i have only enabled Topsl1 and not Topsl2 it dissapear both of them. I cant only have one active? And therefore have it expand in width to cover all the space?
As for the problem i have:
I installed module EasySSP and put it to be visible at Topsl1 (and have Topsl2 module to be also visible cause of the above question). But nothing is being displayed. Is there any other prob?
I have been using Easyssp and Slideshow pro for months in our previous site, i have included the url of it, in the info above, hope you can see it. I just did the same moves, installed the module again and put the same settings, but nothing is being displayed 🙁
Thats all, hope you can help
Ps
Also i have posted a ticket about Graphics. Hope you can answer it also, so i work on them 🙂
jimmer Friendjimmer
- December 2006
- 11 times in 1 posts
February 4, 2009 at 10:31 pm #289553<em>@lycaon 109841 wrote:</em><blockquote>Hello, new boy @ Town 🙂
Ps
Also i have posted a ticket about Graphics. Hope you can answer it also, so i work on them :)</blockquote>
Try this hopefully it will work for you….
http://www.joomlart.com/forums/topic/width-of-template-2/
February 4, 2009 at 10:41 pm #289557I see, i will keep it in mind for the question then, ty 🙂
Can i have any help about the Flash i want to have instead of the Slideshow?
This topic contains 4 replies, has 2 voices, and was last updated by lycaon 15 years, 11 months ago.
