  • arikdan Friend
    #196044
    hi,
    i’ve recently also bought a commercial licence for SJ Extensions.
    i wanted to add an extension (SJ Listing Ajax for K2), but the template doesn’t allow this.
    i’ve contacted the support team of SmartAddons and they told me: “Because JA Framework doesn’t allow to load file your_site/plugins/system/plg_sj_k2_listing_ajax/assets/css/styles.css to your site. Please contact with your template provider for help. I try with default template, it load styles.css file normally.”
    so can you help me please?
    the extension should give a Load More Button in every articles pages, like this: http://new.sapir-aguda.co.il/kashach-ra
    thanks!!
    I see that you’re using pagination in this page: http://new.sapir-aguda.co.il/kashach-ra
    I’ve never used this plugin before but, logically, I think that you should disable pagination then you can use the ‘Load more’ button.
    arikdan Friend
    #528051
    thanks,
    but it still don’t work
    i have disabled the pagination
    Which menu item does this page (http://new.sapir-aguda.co.il/kashach-ra) belong to? I’m not familiar with your native language so please send me screenshot hightlighting that menu item.
    arikdan Friend
    #528452
    thanks
    1. ITEM
    The problem seems to come from K2 as in backend settings of above menu item > Layout options > I could not select ‘ja_university_blog’ as template for that page: http://prntscr.com/36arvw
    Each time I change to another layout > save, it rolls back to ‘default’ value. This means that this page still gets default K2 layout while in settings of SJ K2 listing plugin, it’s applied for ‘ja_university_blog’ layout and that’s reason why it doesn’t load necessary css file.
    arikdan Friend
    #529234
    OK,
    so what can i do?
    Please try to take a backup of your site and update K2 to the latest version. If it does not help, please raise this issue to K2 forum to get better assistance.
This topic contains 8 replies, has 2 voices, and was last updated by  Saguaros 10 years, 7 months ago.
