March 26, 2016 at 12:03 pm #904924
Hi, I want to put my own social icons of addThis. Im changing the code of the custom code section in the template but the new icons are not in the same place that the default icons. What im doing wrong? Thank you very much.
The code:
type="text/javascript" src="//s7.addthis.com/js/300/addthis_widget.js#pubid=ra-56f66f93240cbf4a"
Pankaj Sharma Moderator
March 28, 2016 at 1:31 am #905245Hi
Fist kindly go to system > Global config. > Default Editor > NONE .
because editor remove the codes scripts , Then try to add the code again and check .
Also add the AddThis script in template options custom tab > http://prntscr.com/akwq8jHope it helps .
March 28, 2016 at 11:34 am #905456Im only change the code on the custom tab because i want to put my own links in the social icons of the template, so the only thing y do is putting the code generated by addThis on the custom tab.
I understand what you say about the editor, but i think is not my case because im not creating a new module.
March 28, 2016 at 12:24 pm #905495Hi
could u post the url of the page where u published your social module ?
I checked your site in couple of hours ago and there are only social button in the top of articles that were working fine .March 28, 2016 at 5:08 pm #905798This reply has been marked as private.Pankaj Sharma ModeratorPankaj Sharma
March 29, 2016 at 1:42 am #905951Hi
Its not issue from the template . You are using Addthis script that behave like this . You can switch to default Joomla template and use the script in i, you will see same results.I think you need to check your Addthis account to limit the features .AuthorPostsViewing 6 posts - 1 through 6 (of 6 total)This topic contains 5 replies, has 2 voices, and was last updated by Pankaj Sharma 8 years, 7 months ago.
