Viewing 5 posts - 16 through 20 (of 20 total)
  • turgut Friend
    #292212
    Please check this live site as well http://www.cukurova-idek.org/ it is happening more often there I need you guys help to resolve this issue.
    Turgut
    mihirc Friend
    #292300
    I seriously do not see the problem. Maybe u should try to check it on another PC / Mac.
    If no, then this is how you use z-index:
    1. Open the template_css.css file.
    2. Find the css styling for #ja-mainnav (use the find function if u want.)
    3. The code will currently have the below mentioned code:
    <blockquote>#ja-mainnav {
    background:transparent none repeat scroll 0 0;
    }</blockquote>
    CHANGE IT TO:
    position:relative;
    z-index:25;
    }</blockquote>
    4. Find div#ja-slideshow-wrap in template_css.css (same file as above)
    5. The current code will look something like this:
    <blockquote>div#ja-slideshow-wrap {
    background:#4F4F4F none repeat scroll 0 0;
    border:3px solid #CACACC;
    overflow:hidden;
    width:407px;
    }</blockquote>
    CHANGE IT TO
    <blockquote>div#ja-slideshow-wrap {template_css.css (line 1360)
    overflow:hidden;
    position:relative;
    width:407px;
    z-index:20;
    }</blockquote>
    What we have done is put the menu above the slideshow. All the corresponding links should be coming above it now.
    I AM NOT SURE THIS WiLL WORK, CAUSE THE MENUS LINKS ARE ACTUALLY different.
    When i am making changes, it is breaking the layout if i try to style the elements below. So i dont suggest you doing it, as nobody has the problem.
    Regards,
    Mihir Chhatre.
    Regards,
    Mihir C.
    turgut Friend
    #292421
    Hi Mihir
    Your solution seems to work. It is broken if I use transmenu but with suckerfish it looks fine on FF, Chrome and IE . Thank you
    Turgut
    #292472
    Dear turgut!
    I still can’t see the problem on your site but i highly recommend you try to fix it following way below :
    Open template_css.css file in templates/ja_nerine/css/ folder, find following code section at about line 1361 :
    overflow:hidden;
    position:relative;
    width:407px;
    z-index:20;
    change to :
    overflow:hidden;
    width:407px;
    z-index:20;
    hope can help you !
    turgut Friend
    #292551
    Thank you very much. What Mihir suggested has fixed the problem. I do not want to touch again.
This topic contains 20 replies, has 5 voices, and was last updated by  turgut 15 years, 10 months ago.
