edd Friend
edd
- May 2006
- 8 times in 2 posts
October 1, 2008 at 7:40 pm #133942Hi there,
I have a problem with trying to enable/disable the Menu Module: Split/Css/Moo/Dropline
I’m working on local by the moment
Firts I’ve installed a new joomla 1.5.7 version, then I installed the template and into
Extentions >> Template Manager, JA_Genista
when I try to change the menu to Moo (for example), I’ve this error:Parse error: parse error in c:program fileseasyphp1-8wwwmysitetesttemplatesja_genistaja_menusCSSmenu.class.php on line 11
Then I decided to install directly a quick version, and I have the same problem… :confused:
Anybody has any idea?…
I have also this message into the template manager, at left (I dont know if it is normal):
Menu Assignment
Menus: Cannot assign default template.Please I need some help with this
Thanks a lot
Menalto FriendMenalto
- May 2007
- 531 times in 361 posts
edd Friendedd
- May 2006
October 1, 2008 at 8:02 pm #273473Hi Menalto, thanks for your reply…
so on line 11 it says:
defined(‘_JEXEC’) or die(‘Restricted access’);
You said to use XAMPP… do you think that if I install direct on line I wont have this problem?
Do you think the problem is because I’m working on local?Thanks for reply you can bring me
- May 2007
October 1, 2008 at 8:24 pm #273475I dont think you get this problem on your live site.
But try out this here: http://www.apachefriends.org/en/xampp.html
I have used it for years and never had any sorts of problems with it.
I know many use WAMP as local server, but with bugs and errors…
With XAMPP i have never had any, only thing is to turn off Skype when you install it.1 user says Thank You to Menalto for this useful post
edd Friendedd
- May 2006
October 1, 2008 at 8:45 pm #273476Thanks a lot Menalto…
I will try XAMPP.. i was using easyphp… I will tell you later😉
edd Friendedd
- May 2006
October 1, 2008 at 10:40 pm #273483Hi there again…
uuhhhmm I’m still having problems with this template
I’m using now XAMPP and same error…
Even using a quickstart of Genista there is no “navigation” in the menu :confused:
Sorry mate but I think there is a error or a bug with this template, anyone has any idea?
mj1256 Friendmj1256
- June 2007
- 225 times in 118 posts
October 1, 2008 at 11:20 pm #273487Hey menalto, i use xampp too. No problems for me either
edd Friendedd
- May 2006
October 1, 2008 at 11:23 pm #273488Well I dont know what’s happens but I just install a new fresh qickstart 1.5.7 version on line this time… and there’s no way… same error: no way to enable/disable navigation menus (Split/Css/Moo…)
I dont understand…
Any idea? :confused:
edd Friendedd
- May 2006
October 2, 2008 at 7:51 am #273531:(( ehhhmmm I really need some help with this problem…
anyone can install a new fresh genista web site 1.5.7 (just to test) to know if the problem is on the package I downloaded?
Thanks a lot
- May 2007
October 2, 2008 at 8:08 am #273532working on it now
- May 2007
October 2, 2008 at 8:19 am #273533Replace the file CSSmenu.class.php with the one attached here, you find it in the templatesfolder/ja_menus
- May 2007
October 2, 2008 at 8:21 am #273534If you dont wanna replace it you can open up that file and find this line here at the very top:
<?php/*------------------------------------------------------------------------
And replace it with this here:
<?php /*------------------------------------------------------------------------
edd Friendedd
- May 2006
October 2, 2008 at 8:57 am #273540JUST GREAT…
it works like a charm 😀
Thanks a lot Menalto, you rock!!!!
BIG BIG BIG THANKS
- May 2007
October 2, 2008 at 12:04 pm #273597coolies, i reported this in as a bug and they will update the package asap
October 3, 2008 at 1:12 pm #273748<em>@Menalto 83561 wrote:</em><blockquote>Replace the file CSSmenu.class.php with the one attached here, you find it in the templatesfolder/ja_menus</blockquote>
Thank you , I have the sama problem when I replaced CSSmenu.class.php with the old one , my problem was solved.
This topic contains 15 replies, has 4 voices, and was last updated by Cansun 16 years, 3 months ago.
