il_bujia Friend
il_bujia
- May 2013
- 2 times in 1 posts
February 21, 2014 at 11:35 am #195040Hi
I’am working with the design of my web on 1024×768 resolution.I use Jat3 framework/T3 blank template with Joomla 3.2
I created a new layout for my contact section,and put a spotlight instead of mainbody block.I give two position for the spotlight,and put a module for a contact form(position1),and another module for google maps(postion3).
In all responsive layout,the two position of spotlight are one beside the other,but when I see in my computer at 1024×768 one module is on top and the other at the bottom.How can I make to put one beside other at this resolution altough I resize the window more smaller?
A put a picture of what I am talking about.Here is my site,you have to click in contact section.If you see three folders,you have to clik in the folder called web.
Thanks in advance
chavan Friend
chavan
- October 2014
- 1440 times in 1290 posts
February 22, 2014 at 4:31 am #523857you site Url http://89.130.86.57 is not working. Please post the correct url, so I can suggest you in a right way.
1 user says Thank You to chavan for this useful post
il_bujia Friendil_bujia
- May 2013
February 22, 2014 at 9:05 am #523878Hi
Sorry,I work on a local server and I closed it yesterday.Now is open again.Many thanks for your help
chavan Friendchavan
- October 2014
Viewing 5 posts - 1 through 5 (of 5 total)This topic contains 5 replies, has 2 voices, and was last updated by il_bujia 10 years, 10 months ago.
