  • kugelmeier Friend
    #910733
    Hallo,
    why the 3 Spotlight content blocks are on my site not like the Demo website?
    I filled in the "Custom HTML module" for every position…
    Klaus
    1. screen-1
    Pankaj Sharma Moderator
    #910965
    Did u solved it ?
    I can see the Modules are showing fine on your site : http://prntscr.com/apj7h4
    Kindly re-check and update me .
    kugelmeier Friend
    #911082
    Hallo,
    oh no – I didnt solved it, there are only tabels <table>. You can see it in my Admin, module called "Füller 1". Must I have to use K2 for this module positions? I dont use it.
    Klaus
    #911089
    I am not able to understand you last post . Did u solved the spotlight position issues ?
    Because it seems fine at my end .
    In these positions, there are custom html module are used not K2 modules . Find the details info in the documentation Here
    In doc look for spotlight module Here : http://prntscr.com/apkre7
    kugelmeier Friend
    #911117
    Hallo,
    NO, I didn`t solved it.
    The modulesuffix "module-bg bg-gray-dark ja-animate dl-1 fadeIn" does NOT work.
    I replace it with tables but thats not the solution. Please go in the Admin.
    Klaus
    1. screen-2
    #911127
    Noticed the suffix issue http://prntscr.com/apl988
    Kindly remove the html formatting of table and add the suffix with a single blank space .
    It will work .
    kugelmeier Friend
    #911137
    Thanks, that was the issue – but now the position 2 is green and not blue. Is it ok?
    Klaus
    1. screen-3
    #911168
    Yes its fine working as expected . its using cyan color suffix and same in output : http://prntscr.com/aplpfv
This topic contains 7 replies, has 2 voices, and was last updated by  Pankaj Sharma 8 years, 8 months ago.
