  • rain1 Friend
    #123925
    I´ve been looking through the forum and have tried out the different advice given but I am still not seeing the images in the spotlight module. I have changed the image size to what was recommended, checked the path of the images, position of the user 1,2,5 and am still not able to solve the problem. All text is displaying correctly.
    Also, between the first and second spotlight box I have no spacing but between the second and third there is a small space. Any idea what this is?
    Any help would be appreciated.
    mfcphil Friend
    #233384
    Have you cut and pasted the link to your image from the Media Manage into the correct place…..if you have try deleting the bit of text before the http: and delete the bit after gif or jpeg
    Make sure the gif or jpg bit is correct when I used this template I lost the images because I had jpg in the link when the images were gif
    worked for me.
    rain1 Friend
    #233445
    Thanks 😀 That solved the problem. I appreciate your help
    mfcphil Friend
    #233448
    Very pleased to help
    Good luck with your site.
    mfcphil
This topic contains 4 replies, has 2 voices, and was last updated by  mfcphil 17 years ago.
