librandi Friend
librandi
- February 2012
- 2 times in 2 posts
September 12, 2016 at 4:26 pm #967686Hi,
In this page http://www.keebboo.com/it/home-it-it.html the style is in keebboo/mybooking/……. why it can happen? Ho I can solve this problem?
September 13, 2016 at 3:23 am #967797Hi
i am not able to get the issue on your screenshot , could u provide some more details which style is not working on site ?librandi Friendlibrandi
- February 2012
September 13, 2016 at 6:03 am #967828thanks, I try to explane better, in http://www.keebboo.com/it/home-it-it.html some modules take a css not from template but in another file css in mybooking folder, for example the module "cosa offriamo" (team style 4)
take the css from http://keebboo.com/mybooking/html/css/text.css.
How I can solve this problem?
thank youPankaj Sharma ModeratorPankaj Sharma
September 13, 2016 at 6:29 am #967832Hi
Did u added this external css file in your head file or they used on site by any other module ?
I can see the file is loaded on your site : http://prntscr.com/checmr
and the style is applied on p tag , P tag is standard tag so it applying styling on it .
To avoid it either u will remove the code of modify the code with classes name where they are used .librandi Friendlibrandi
- February 2012
September 13, 2016 at 6:36 am #967838thank you very much
AuthorPostsViewing 5 posts - 1 through 5 (of 5 total)This topic contains 4 replies, has 2 voices, and was last updated by librandi 8 years, 3 months ago.
problem with style
