gringo211985 Friend
gringo211985
- May 2012
- 123 times in 27 posts
June 21, 2017 at 11:11 am #1043263Hi there,
Bit of an urgent problem here with Akeeba. I built a site on a sub-domain as to not interfere with the live site I was replacing. I finished the site and took an Akeeba backup and published to my live url.
The problem is that now I am facing is that all of the custom code and styling has disappeared when I go to edit on the live url.
Please can you help me out with this or will I have to go through and redo all the styling?
If you could help me as soon as possible I would appreciate it.
Thanks,
RichardSaguaros ModeratorSaguaros
June 22, 2017 at 4:20 am #1043401Hi Richard,
Maybe cache issue? as I can see it looks the same in both site now.
gringo211985 Friendgringo211985
- May 2012
June 22, 2017 at 10:42 am #1043514Hi Saguaros,
Both the sites look the same, but when you go to edit the page from front end on the new site it loses the styling. So I can’t edit any page without losing the styling for the site.
Please can you check again on the new site by trying to edit a page? Please do not save the page as it will lose the styling.
Thanks,
June 23, 2017 at 4:47 am #1043718Hi Richard,
I checked the new site and saw that the custom css for ‘All Pages’ is not enabled, could you try to add css into this option into new site as in your old site?
- May 2012
June 23, 2017 at 9:14 am #1043779Hi @saguaros
It’s not just the custom.css that is missing, there are header scripts, block settings, images and all sorts that get wiped when I go to edit the site. If I paste in my custom.css then it will remove all the styling from the blocks etc.
How can I fix this? Do I have to fix manually or can you fix this?
Thanks,
June 27, 2017 at 2:04 am #1044341This reply has been marked as private.VariFrame FriendVariFrame
- November 2015
- 3 times in 2 posts
September 5, 2017 at 3:32 pm #1060506Same here 🙁
bositman Friendbositman
- August 2012
September 5, 2017 at 8:46 pm #1060546You can’t fix it it’s a JA Builder bug (one of the thousands…) . Anyone can replicate it instantly on a sandbox, but the staff here always prefer to tell you if you changed browser or if you cleared your cache. Like that has anything to do with missing custom colors and even if it did, cache corruption is STILL your program’s issue, not ours.
September 8, 2017 at 1:38 am #1061082Hi,
As discussion with @VariFrame , when you backup site from Akeeba and restore to a new site, pls go to the site where you take backup, export pages > then import to the new site.
This topic contains 8 replies, has 4 voices, and was last updated by Saguaros 7 years, 3 months ago.
