spiralgr Friend
spiralgr
- May 2015
- 4 times in 1 posts
September 2, 2015 at 5:09 pm #681321Hello again, there is a problem with submenus what do i mean is that if the submenu item is below a certain point and over an image then in isotope layout it is not clickable.
If you want to recreate this go to Activities hover over the menu activities everything is normal, go to activities->hiking hover over activities menu last two menu items are not clickable.
pavit Moderatorpavit
spiralgr Friendspiralgr
- May 2015
- May 2015
September 2, 2015 at 6:46 pm #681372<em>@spiralgr 490200 wrote:</em><blockquote>Thank it is working, just with an add a ; after z-index:1</blockquote>
Sorry i forgot to add it
Glad you solved it
Best regards
September 2, 2015 at 6:46 pm #747309<em>@spiralgr 490200 wrote:</em><blockquote>Thank it is working, just with an add a ; after z-index:1</blockquote>
Glad you solved it
Best regards
This topic contains 7 replies, has 2 voices, and was last updated by pavit 9 years, 3 months ago.
