  • Tech-xml Friend
    #159310
    I activated the plugin (System – Upgrade Mootools), started a small picture at the top of the template.
    As shown in the image below:
    10863
    I am using only the basic plugins joomla.
    By switching to another template the problem disappears
    Note: the problem only occurs on article pages of joomla.
    Submit a ticket for the suport
    1. Capturar
    it ‘s issue from the Joomla Tooltip has some wrong in css when enabled the plugin.
    the issue only appear when you accessed the front end with a account having the Editor level.
    You can add the following code into the template.css file to resolve the issue
    .tip-wrap {
    display: none;
    Tech-xml Friend
    #373893
    Thanks, Solved
This topic contains 3 replies, has 2 voices, and was last updated by  Tech-xml 13 years, 11 months ago.
