  • Jensen Neo Friend
    #167798
    I have created a new template based on T3 Blank for this site. However, there seems to be a system css overriding my template.css hence certain elements of the site are not displaying as it should have.
    For e.g. body#bd, in my template css, I have already overwritten it to display #E7E7E7. However it does not appear so. Upon investigation using Firebug, I realised that another css (“http://sal.outofbox.com.sg/index.php?jat3action=gzip&jat3type=css&jat3file=t3-assets%2Fcss23cf1.css?v=51”) is actually overwriting my template.css.
    Please advise where does this css derives from and how may I disable it?
    syahzul Friend
    #408528
    when u developing template, i advice you to
    1. turn on Development Mode
    2. Compress CSS – set to No
    3. Compress JS – set to No
    4. Clean T3 cache
    after you finish, then you can set it back as original settings.
    Jensen Neo Friend
    #408531
    I have followed your instructions but however the issue remains. Is there any other possibilities?
    syahzul Friend
    #408533
    since you are using more_contract_red theme, try change it in your :
    /templates/singaporelawwatch/core/themes/more_contrast_red/css/template.css
This topic contains 4 replies, has 2 voices, and was last updated by  syahzul 13 years, 4 months ago.
