  • lavers69 Friend
    #192538
    I am having a problem with the template manager for my JA MERO site. It seems as if the t3 framework is loading twice on the template manager page. I have tried uninstalling t3 and then reinstalling, but I still have the same problem (see image). The issue is that it is stopping me from doing some changes. This issue first appeared when I was creating a megamenu for the Main Menu. Any ideas how to resolve it?
    TomC Moderator
    #513468
    How does it appear in your site administration? Can you provide a screen capture?
    lavers69 Friend
    #513615
    Not sure if the printscreen attachment loaded, but basically about halfway down the page the Template Manager loads itself again
    1. t3
    Try to remove the clearfix style in JA Typo plugin as I mentioned in this thread: http://www.joomlart.com/forums/topic/template-manager-not-hiding-overview-blocks-when-changing-tabs/#post-512156
    Hope it helps 🙂
    lavers69 Friend
    #513756
    Thanks for your response. I don’t have the JA Typo plugin. Should this be installed?
    You can PM me admin & ftp account of your site, I will try to check this
    lavers69 Friend
    #514652
    Do you have any update on this issue with the template manager and t3. My email linked to my account doesn’t connect here in Qatar.
    best regards
    Iain Laverock
    Hi Iain,
    The issue was fixed by commenting this line of code:
    $close = array_pop($endtags) . '</form>' . $close;
    in file: pluginssystemt3includescoreadmin.php
    Please have a look and let me know if you need further helps.
    lavers69 Friend
    #516721
    Thank you for this. It has worked. I really appreciate your help on this.
    Iain
This topic contains 9 replies, has 3 voices, and was last updated by  lavers69 11 years ago.
