  • jschroeder Friend
    #182468
    I am getting this error below no matter what template i use on the version 3 framework. There is a line of code not correct somewhere. I keep receiving this error
    Warning: Invalid argument supplied for foreach() in/plugins/system/jat3v3/t3v3base/html/mod_menu/default.php on line 23
    How do i fix this i know that the t3v3 framework is still not an official release yet, but how do i fix this?
    thanks,
    Josh
    Ninja Lead Moderator
    #473885
    Currently, we only have JA Brisk and JA University Template supported JAT3v3 framework. We are in progress of upgrading J2.5 templates to run with JAT3v3 framework.
    Regarding on your problem, please post your site url here, if possible PM me admin and FTP account and tell me how I can duplicate the same error , i will diagnose it.
    jschroeder Friend
    #474261
    Hi, this seems to be just a general problem with the t3v3 framework running on joomla 2.5.8. I did a fresh install of joomla 2.5.8 with nothing installed but the framework and template. When you click through the styles for the template then go under the template this error appears on the top of the page and it actually causes the joomla navigation at the top to completely dissapear where it says site, users, menus, content etc.
    Hi, i see this is a bug still in the framework it was reported in the bug section
    http://www.joomlart.com/forums/topic/control-panel-warning-messes-up-all-controls/
    Any Idea when there will be a final release on the t3v3 framework?
    thanks,
    Josh
    #474349
    Hi Josh,
    We shall fix this error soon and hope release it next week.
    jschroeder Friend
    #483449
    Hi, this error was fixed but has now reappeared i am using ja brisk 1.0.1 and t3v3 1.0.3 framework. Also i am running joomla 2.5.9. I have a feeling the recent update to joomla 2.5.9 is inteferring with the t3v3 framework because everything was working before this.
    Is this a bug i see someone posted this for the joomla 3.0.2
    https://github.com/t3framework/t3/issues/19
    How do i get this error to go away?
    #483526
    You can duplicate the same error with empty menu item. This bug was fixed or you can update it as follow
    + Download and extract my attached file
    + Copy paste to
    <blockquote>/plugins/system/jat3v3/t3v3base/html/mod_menu/default.php</blockquote>
    1. default.zip
This topic contains 6 replies, has 2 voices, and was last updated by  Ninja Lead 11 years, 10 months ago.
