April 27, 2015 at 3:08 am #205860
Hi, I’m working on a website (right now with a temporary url before putting in a production site) I’m using Ja Bistro template, joomla 3. My first problem was the Quickstart pack never install (just stuck in loading after click in continue after putting the name of the site, user, etc). So I decided to install joomla via Cpanel, update it to latest version, then install every component separate.
My second problem was With Ja Extension manager, when I tried to enter there, gave me this error
1146: Table ‘u713058455_uruqe.p24s_jaem_services’ doesn’t exist SQL=SELECT * FROM p24s_jaem_services AS t WHERE 1 ORDER BY t.ws_name
I corrected using the #6 post of this link http://www.joomlart.com/forums/topic/table-doesnt-exist-error-when-installing-ja-extentions-manager/
Now I have this error 1146 Table ‘u713058455_uruqe.p24s_jaem_log’ doesn’t exist SQL=SELECT * FROM p24s_jaem_log WHERE 1
I installed latest version of Ja Extension Manager.
Thanks in advance. and sorry for my english
jooservices Friendjooservices
- October 2014
- 1245 times in 1121 posts
April 27, 2015 at 3:13 am #568357Hi there
# Please check to make sure you have this table jaem_log in your database.
# In case you can’t do that please try
— Uninstall JAEM
— Clean all tables of it
— Reinstall it.
If you still can’t do that. Please provide your site backend & Cpanel access. I’ll help you do that.Thank you,
Viet Vujooservices Friendjooservices
- October 2014
April 27, 2015 at 3:13 am #733453Hi there
— Uninstall JAEM
— Reinstall it.
Viet VuApril 27, 2015 at 3:21 am #568363Yes, I already try, I reinstall, the database dont exist. I send the data to access via PM. Thanks
April 27, 2015 at 3:21 am #733459Yes, I already try, I reinstall, the database dont exist. I send the data to access via PM. Thanks
- October 2014
- October 2014
April 27, 2015 at 4:09 am #568370Yes, It worked, I can access to the component! Thanks a lot!!! If you dont mind, can you tell me how you did it? Just for learn.
April 27, 2015 at 4:09 am #733466Yes, It worked, I can access to the component! Thanks a lot!!! If you dont mind, can you tell me how you did it? Just for learn.
- October 2014
April 27, 2015 at 4:40 am #568377Hi there
I only do uninstall & reinstall
Thank you,
- October 2014
April 27, 2015 at 4:40 am #733473Hi there
Thank you,
Viet Vu -
This topic contains 11 replies, has 2 voices, and was last updated by jooservices 9 years, 8 months ago.
