  • alynst Friend
    #123040
    Hello:
    I have installed tabs & slides and have noticed a dot in between the tabs. It’s the same dot you see by each menu item. Is there a fix for this problem?
    alynst Friend
    #230463
    Ok, I solved it, But I will post the problem incase someone else uses the tabs and slides module available for Joomla:
    Here was the problem:
    I was getting the ul li image (list “image”) in between my tabs. To solve this issues, I edited the JA_Wisterly css file:
    Search for the following code and remove it. Problem solved.
    ul li {
    padding-left: 35px;
    background: url(../images/bullet-list.gif) no-repeat 20px 5px;
    line-height: 170%;
This topic contains 2 replies, has 1 voice, and was last updated by  alynst 17 years, 1 month ago.
