  • Luna Garden Moderator
    #961879
    Please check if motool JS Library is called on your site, if not, try to call it.
    If Motool is called, then do as bellow: Try to replace $( to document.id( in above code
        function jaMagicSelect(controller, lid) {
            controller = document.id(controller);
            if(controller.hasClass('opened')) {
                controller.removeClass('opened');
                controller.addClass('closed');
                document.id(lid).setStyle('display', 'none');
            } else {
                controller.removeClass('closed');
                controller.addClass('opened');
                document.id(lid).setStyle('display', 'block');
        function jaMagicSelectClose(controller, lid) {
            controllerparent = document.id(lid).getParent().getElement('.select');
            if(controllerparent.hasClass('opened')) {
                controllerparent.removeClass('opened');
                controllerparent.addClass('closed');
            } else {
                controllerparent.removeClass('closed');
                controllerparent.addClass('opened');
    And change for other JS code if you still get the same error message on JA K2 Filter.
    attex Friend
    #961907
    Why i can’t see your reply-post?
    attex Friend
    #961970
    Thanks for your answer.
    Problem solved with mootools
This topic contains 3 replies, has 2 voices, and was last updated by  attex 8 years, 3 months ago.
The topic ‘Problem with tags and magic select.’ is closed to new replies.
