  • andynet69 Friend
    #120901
    I have a problem with the site, as he/she is seen in the photo.
    Can someone help me? thanks
    1. mobilvemagazine
    bigrk Friend
    #222309
    Post your url so we can take a closer look.
    andynet69 Friend
    #222311
    <em>@andynet69 18430 wrote:</em><blockquote>I have a problem with the site, as he/she is seen in the photo.
    Can someone help me? thanks</blockquote>
    you are right: http://www.mobilve.com
    bernhar Friend
    #222312
    It looks like you modified the template. Just remove the code you see above the site.
    andynet69 Friend
    #222313
    <em>@bernhar 18443 wrote:</em><blockquote>It looks like you modified the template. Just remove the code you see above the site.</blockquote>
    Is this the problem that I don’t succeed in finding the part to eliminate, do you know how to help me? thanks
    bernhar Friend
    #222314
    If you modified something, tell me what. There are several places where these code snippets could be.
    First guess: Related to Google!?
    Did you insert the following code manually?
    <meta name=”y_key” content=”moNqPJjxyU5/hbgcSOnPXUFc83cSh7SXC0Hjih0MEKE=” />” />
    <meta name=”verify-v1″ content=”moNqPJjxyU5/hbgcSOnPXUFc83cSh7SXC0Hjih0MEKE=” />” />
    andynet69 Friend
    #222318
    <em>@bernhar 18448 wrote:</em><blockquote>If you modified something, tell me what. There are several places where these code snippets could be.
    <meta name=”verify-v1″ content=”moNqPJjxyU5/hbgcSOnPXUFc83cSh7SXC0Hjih0MEKE=” />” /></blockquote>
    thanks for your help, the problem that I didn’t see it in the file index.php, has discovered then that was a mambots, I thank a lot you..
This topic contains 7 replies, has 3 voices, and was last updated by  andynet69 17 years, 6 months ago.
