January 11, 2011 at 12:32 pm #158602
I’ve installed JA Cloris with Quickstart and I have problems to see the default page. When I clicked my domain there are the following message:
Fatal error: Call to undefined function mb_internal_encoding() in /home/hostpyme/public_html/nubecms.com/components/com_k2/helpers/route.php on line 55
Thanks!
Andreu
aman204 Friendaman204
- January 2010
- 418 times in 356 posts
January 11, 2011 at 6:50 pm #371365Probably, this can help 🙂
1 user says Thank You to aman204 for this useful post
January 12, 2011 at 11:12 am #371477Thank you very much.
2Patrick Friend2Patrick
- July 2008
- 11 times in 1 posts
February 19, 2011 at 10:52 am #377463Just downloaded the JA Cloris Quickstart ( J 1.5 )
However, during installation it does not allow the installation of sample content and final screen is :Notice: Undefined index: DBtype in /home/marretts/public_html/installation/installer/models/model.php on line 764
Fatal error: Call to undefined method JException::getNullDate() in /home/marretts/public_html/installation/installer/helper.php on line 290
Is there a problem with JA Cloris ( 1.5 ) Quickstart ?
I have tried other JA Quickstarts but this is the 1st time I get an installation problem.
- January 2010
February 20, 2011 at 5:34 am #377518<em>@2Patrick 222503 wrote:</em><blockquote>Just downloaded the JA Cloris Quickstart ( J 1.5 )
I have tried other JA Quickstarts but this is the 1st time I get an installation problem.</blockquote>
Please ensure that you have followed the steps outlined here for installing quickstart::
http://www.joomlart.com/forums/topic/how-to-install-joomlart-quickstart/
Mainly, I would suggest to go with this method::
<blockquote>Upload the zip file to your host and extract it using cPanel or other File Manger Tools if possible.</blockquote>
as it would have less chances for missing files during installation
- July 2008
February 21, 2011 at 2:58 pm #377772Hi
I must installed quiet a few quickstarts since 2008.I am familiar with the steps as indicated above.
But I still get the errors ..in fact the 1st error comes after the initial configuration ( snap attached )
THIS IS THE 1st time something like this has happened.
AuthorPostsViewing 6 posts - 1 through 6 (of 6 total)This topic contains 6 replies, has 3 voices, and was last updated by 2Patrick 13 years, 6 months ago.
Problem with template installation
