February 17, 2013 at 6:18 am #185028
I think the template overrides with the JA Vintas template need to be updated for the latest version of Virtuemart. I have Virtuemart v2.0.18a installed and text on the checkout page (after clicking “Checkout Now” from the Cart) looks different than the JA Vintas demo. In the ADD/EDIT BILLING ADDRESS INFORMATION section, there’s additional text showing up, like “Shopper Information” and these few lines of text:
Bill To
Shopper Information
Bill ToI haven’t made any changes to the language file, and I’m pretty sure this happened after updating to the latest version of virtuemart. Here’s a screen print:
And this is what it looks like on the Demo:
I think the situation is with the override file ja_vintas/css/html/com_virtuemart/user/edit_address_userfields.php but I can’t figure out how to make the appropriate change to fix it. Any assistance would be greatly appreciated.
February 18, 2013 at 4:36 am #483734Hi,
There are some changes in new version of Virtuemart, we will update for this template soon, please check our blog to get updates.
Thanks for your reporting 🙂
Adrien GEORGE FriendAdrien GEORGE
- 2 times in 1 posts
December 27, 2013 at 2:15 pm #516680<em>@Saguaros 360609 wrote:</em><blockquote>Hi,
Thanks for your reporting :)</blockquote>
Hi there,
I have the same problem, can you help me getting rid of the 4 times same phrase :
have a look here :Or you can find it here : http://www.ekipazofootball.com/fr/user/editaddresscartBT
Thanks in advance !
Saguaros ModeratorSaguaros
December 30, 2013 at 9:28 am #516848Hi guys,
This is a bug of template, I’ve already reported to team, they will fix and update it soon. You can check the status here: http://pm.joomlart.com/browse/JATCVINTAS-154
In the meantime, try to take a BACKUP of your site and update this template to the latest version. Then go to this directory: /templates/ja_vintas(your_default_template)/com_virtuemart/user remove this file: edit_address_userfields.php (backup it first)
Once done, clean all caches and let me know how it goes.
AuthorPostsViewing 4 posts - 1 through 4 (of 4 total)This topic contains 4 replies, has 3 voices, and was last updated by Saguaros 10 years, 11 months ago.
