  • Pankaj Sharma Moderator
    #1000815
    I checked your site and click on read more work fine. For the contact, you have to assign the contact category or article to a menu, so when u click on read more it open under that menu.
    Not under default page.
    Turn off SEF option from global. config. to check the menu URL.
    propolis Friend
    #1000821
    Thank you for the quick reply
    Sorry, from the above I cant find how to get this could to work as I dont have the option (unless I am overlooking something)
    The contacts is from a component called Contact Enhanced. I have a menu link for Contacts, and that works, but cant work out how to make the contact Read More to use that link? 🙁
    Eddie
    #1000824
    on position 1 there is contact module type > Articles category.On which u selected a category contact to pick the articles from this category http://prntscr.com/dtaham
    If this category does not associate/selected under a menu it will open under the default page. You have to create a hidden menu type category blog and select this contact category so when u click on read more it open under the menu you created.
    Hope it helps.
    propolis Friend
    #1001179
    Tried various options but cant get this to work. Have you got any samples I can follow. Tried some ideas from Joomla, but no success
    Eddie
    #1001181
    Just apply the suggestion above and it will work, you have to associate/add the category in a menu so it open under that menu.
    propolis Friend
    #1001190
    Thanks for quick update. Tried that, but it does work. Is it because I am trying to display a component?
    I am trying to get the Read More to display this link: http://www.cyber-plaza.co.uk/jauniversity/index.php?option=com_contactenhanced&view=category&id=100&Itemid=118
    Eddie
    #1001191
    In case, you would like to display the contact page.
    I suggest you to use custom html module and add the image and link the read more to your contact page.
    Because articles category module work only for the Joomla articles.
    propolis Friend
    #1001620
    Thanks for the new information / idea
    This worked well
    Thank you for the support
    Eddie
This topic contains 8 replies, has 2 voices, and was last updated by  propolis 7 years, 11 months ago.
The topic ‘Problem with template Position 1’ is closed to new replies.
