  • trextrex Friend
    #186761
    Hello friends
    I need your quickly response!!
    Apparently when the booking is working it makes failures and does not display the origins or destinations of the booking
    Consulted the developer of the booking, it tells me that it is a problem of the template cache.
    I’ve disabled the cache and then the fault is intermittent, with different browsers.
    I need your urgent help for web delivery already!
    Thanks for all!
    phong nam Friend
    #490033
    Hi trextrex,
    Did you try to set Yes to Development Mode in Template Manager >> JA Ironis – Default >> Global tab ? So that it will completely disable all cache.
    * If you still face this cache issue, PM me your admin account for further checking.
    Regard
This topic contains 2 replies, has 2 voices, and was last updated by  phong nam 11 years, 9 months ago.
