  • victoriano miguelamador t Friend
    #117521
    Hello:
    This is a Fantastic template….congratulations.
    PROBLEMS
    1- I use the Orstio bridge for SMF, and the module for LOGIN, in IE this make that the others modules in left or right, and the proper mod Login , drop at the bottom of the R or L, and it appear on (cover) the others. (I know that the problem can fix it putting in template.css a position absolute in the first div wrapper, but in this template i donĀ“t know how).
    2- In Firefox i am unable that the size font tool work, when i type in any appear in the http:// mysite.com/ #increase (in IE 6, works fine).
    3) Can any tell me where can i read how works the mod_ja_coolads, i configure it but i dont know where and
    how put a Tip for example or any other????
    Thanks in advance
    drumbrad1 Friend
    #211430
    Having the same problem with the bridge. I was previously using JA Zibal, and I didn’t have this problem.
    #211436
    Having the same problem with the bridge. I was previously using JA Zibal, and I didn’t have this problem.</blockquote>
    Thanks for your answer, for the moment i am not ALONE
    There are any people with J-SMF-Orstio Bridge without problems in this template?????
This topic contains 3 replies, has 2 voices, and was last updated by  victoriano miguelamador t 18 years, 2 months ago.
