  • Markus Friend
    #209063
    im currently playing around with the dekor template and for unknown reasons the Our services Module and the featured Projects module are not showing on the home page anymore. They are active and assigned and the template default style is assigned to all menu selections aswell.
    If i switch to any of the other themes ( Red , Yellow, …) the site works just fine.
    Any hints or ideas how i can fix this ?
    I have it running locally so i cant give you access at the moment.
    Cheers
    Markus
    Markus Friend
    #578172
    never mind i found it.
    RTFM … 🙂
    Markus Friend
    #644463
    RTFM … 🙂
    Markus Friend
    #743096
    RTFM … 🙂
This topic contains 4 replies, has 1 voice, and was last updated by  Markus 9 years, 5 months ago.
