  • melquiades Friend
    #171149
    I tried to install several times the template, but anytime i try to create/change categories or articles, both on Joomla or on K2 i’ve this kind of error…
    Fatal error: Call to undefined method stdClass::onDisplay() in /home/sinistra/public_html/sito/libraries/joomla/html/editor.php on line 268
    what’s wrong?
    TomC Moderator
    #426750
    Might I inquire as to what method you utilized to upload/install your template?
    melquiades Friend
    #426757
    <em>@TomC 285371 wrote:</em><blockquote>Might I inquire as to what method you utilized to upload/install your template?</blockquote>
    uploaded the quickstart with filezilla
    TomC Moderator
    #426758
    <em>@melquiades 285383 wrote:</em><blockquote>uploaded the quickstart with filezilla</blockquote>
    Hmmm … did you install the sample data as well as part of the installation?
    melquiades Friend
    #426759
    <em>@TomC 285384 wrote:</em><blockquote>Hmmm … did you install the sample data as well as part of the installation?</blockquote>
    yes, i did. What’s wrong?
    TomC Moderator
    #426761
    <em>@melquiades 285368 wrote:</em><blockquote>
    </blockquote>
    Can you do me a favor and post that line here?
    Also, which browser(s) are you using?
    melquiades Friend
    #426762
    <em>@TomC 285387 wrote:</em><blockquote>Can you do me a favor and post that line here?
    Also, which browser(s) are you using?</blockquote>
    http://sito.sinistra18.net/administrator/index.php?option=com_k2&view=category
    mozilla
    TomC Moderator
    #426763
    Your link brings up your administration login screen – I cannot access
    TomC Moderator
    #426764
    Also, when you uploaded your files, what did you use to do so? FTP?
    If so, was it FTP through your webhost CPanel or through an FTP client such as FileZilla?
    melquiades Friend
    #426765
    i just sent u a pvt message to access the admin panel.
    i used filezilla ftp to upload the files
    TomC Moderator
    #426766
    I will try to take a look into this for you . . . I may need to review with our JA Developers – so it may take a little bit longer.
    Appreciate your patience – I know how frustrating something like this can be.
    In the interim, perhaps you can work on other development on your site. Will get back to you a.s.a.p.
    melquiades Friend
    #426939
    ok, i will try, let me know asap 🙂
    jooservices Friend
    #426968
    Once again, this issue we have faced .
    http://www.joomlart.com/forums/topic/set-up-tiris-not-ok/!
    Please try to turn off your Editor plugin : JA Typo.
    4 Editor Button - JA Typo Button Enabled Move Up Public editors-xtd jatypobutton 47
    And upgrade it to latest / correct version to fix it ( we have fixed it in latest version )
    Thank you,
    update: i have disabled it for you.
This topic contains 13 replies, has 3 voices, and was last updated by  jooservices 13 years ago.
