  • INSERM UMS33 Friend
    #870964
    I have a problem with the placement of blocks in the settings "responsive layout".
    In the case 1. If I put the blocks in position 2, 3, 4, and 5 in this way (see fig1) no worries, I get fig2. The block position-2 takes 60% of the space approximately.
    In case 2, the one that I want to do. It’s incomprehensible! By positioning the blocks so they take up half of the page (see fig3), they position themselves anyhow (see fig4 and http://newsite.institut-lwoff.fr/fr site). It’s a mystery to me. It seemed simple enough to do.
    Do you have an idea of the problem?
    1. fig2
    2. fig3
    3. fig4
    4. fig1
    Adresse de Livraison:
    So which order you want it should be? pls also update the admin account of your site so I can have a look: http://static.joomlart.com/images/blog/2015/nov/Add-new-post.gif
    INSERM UMS33 Friend
    #871629
    Hi Saguaros,
    I just gave you the access. If you can resolder my problem and tell me how did you proceed to do so.
    Again thank you for your help
    Good day
    Could you also update screenshot of how you want it should be?
    INSERM UMS33 Friend
    #872997
    I would like the settings in "responsive layout" I did apply on the front end. The settings are those in Fig 3. As you see the blocks are not positioned in the right place. A bug template? You can see the problem in back-end?
    For the module positions in ‘spotlight’ block, it should be displayed in one row in large screen, kindly check the default layout of this template here: http://prntscr.com/9xjv8r
    You can change the width for each module (in each spotlight block) but all of them should display in one row. And I don’t know where the position-15 position comes from.
    INSERM UMS33 Friend
    #873687
    Thank you for your response. I do not understand why you say: "For the positions Module in ‘spotlight’ block, it should be displayed in one row in largescreen"
    In the example you set in http://www.joomlart.com/demo/#ja_platon page in large screen you put several modules on one line. How do you do?
    The module in position 15 would normally be adjacent to the positon 4 (voir position.png)
    1. position
    Which modules in our demo site are you referring to? some screenshots would be helpful here.
    INSERM UMS33 Friend
    #874218
    To make this easier to understand, I simplified my homepage. As you see I have 3 modules (I disabled some "positions"). Positioned a "slideshow, the 2nd in" position2 "and 3rd in" Position3 " (see my screenshots).
    Normally Module 3 should be on the same line as the module 2, set as you can see it overlaps the module 1. Why? Do you have an idea to solve the problem is?
    1. responsive-layout
    2. home
    INSERM UMS33 Friend
    #874414
    I found. The first spotlight is special. Position 2 is set so that the module is superposed on the slideshow. If I use the positions of the 2nd spotlight everything works. It is looking at building the template Ja Plato (https://www.joomlart.com/documentation/joomla-templates/ja-platon) I understood.
    There are still some problems when moving from one screen size to another but better. I think we should enter the code to solve it
    Glad to hear you got it solved!
    If you have further question, let us know.
This topic contains 10 replies, has 2 voices, and was last updated by  Saguaros 8 years, 10 months ago.
