  • jonasrotilli Friend
    #186161
    I have a problem in positioning:
    happens that the “framework” final position user2 (the template demo that has the title Mylo Xyloto New Album) gets behind, “hidden” when I do not use the module position user3, user4, user5, user6, Middle and content-mass-top.
    That is if I do not use both below position user2 it is tucked away behind, if I put a link on user2 can not I click it.
    It’s weird …
    added an example in the Annex and described as Case1 and Case2, Case 1 is where the problem is and Case2 as the demo.
    How to solve this?
    Since already thank you.
    Jonas
    Brazilian rookie
    1. problemaSlide
    phong nam Friend
    #487875
    Hi jonasrotilli,
    I checked your admin side but could not see the issue you have mentioned. For example, when I disable User3, content-mass-top module >> Your user-2 module is still there.
    “f I put a link on user2 can not I click it.” – You can’t click on links because they are invalid links, you need to insert right url into Custom Text area of Agenda (user-2) module. Pls check my snapshot for details.
    * Pls help me to enable your User 3/ content-mass-top module as normal. Thanks!
    Regards,
    Leo
    1. 3-26-2013-3-48-55-PM
    jonasrotilli Friend
    #491163
    Decided otherwise, thanks.
This topic contains 3 replies, has 2 voices, and was last updated by  jonasrotilli 11 years, 8 months ago.
