  • porpeller Friend
    #130331
    hi, using firefox, the “read more” shows the link title that breaks the layout. here is a screenshot:
    the site is http://www.inspiegabile.com
    someone can help me? thank you.
    kalinski Friend
    #257474
    the space on the button is limited, so you should only use a short expression for the read more:
    <a class=”readon” title=”2008, 8 Gennaio, Stephenville, Texas- Caccia all’U.F.O.” href=”/cms/archivio-casi-ufologici/incontri-a-distanza-luci-notturne/2008-stephenville.html”>Leggi tutto…</a>
    porpeller Friend
    #257484
    how could I do?
    kalinski Friend
    #257499
    <em>@porpeller 63748 wrote:</em><blockquote>how could I do?</blockquote>
    The same way you already did it, just shorten it to the above example.
    #257582
    Hi Porpeller
    Kalinski said right, you must edit your read more text
    porpeller Friend
    #257596
    the problem is only with firefox: in internet explorer is visible only “Leggi Tutto” that means read more in italian
    questbg Friend
    #257604
    Buon Giorno Porpeller
    I’m sorry I can’t help much as I am not familiar with your template.
    I checked your site here on a Mac and the same problem in Safari and Firefox:
    It appears that the actual ‘Title’ of each article is being reproduced under your ‘Read More’ button?
    I hope this explanation can make a better understanding for somebody and they can help.
    Great web site! Many congratulations, looks fantastico!
    Chris
    porpeller Friend
    #257621
    thanks questbg! 🙂 this is exactly the problem
This topic contains 8 replies, has 4 voices, and was last updated by  porpeller 16 years, 5 months ago.
