  • danielar Friend
    #186652
    viewing template Ja University on mobile devices, I can not scroll the page by swiping my finger on the images of the slideshow.
    On devices with small screen, oriented in a horizontal position, as the slideshow occupies almost the entire screen, this prevents almost completely the ability to scroll the page.
    It also happens on your online demo.
    Can you help me to solve this problem?
    Thank you very much!
    Ninja Lead Moderator
    #489535
    This is not bug because when you view JA University Template on mobile devices, JA SlideShow Lite module loads full on mobile devices and animation type of module overlap with touchscreen. If you don’t touch JA Slideshow Lite module, it will run normal.
    danielar Friend
    #489581
    Ok, this is not a bug, but if I view JA University Template on mobile devices in orizontal position, JA SlideShow Lite module fit the entire screen, so how can I scroll without touch the JA SlideShow Lite module? :((
    Maybe it’s time to hide the module in mobile devices?
    Can you suggest me any solution?
    Thank’s a lot.
    #489701
    You can disable JA SlideShow Lite module on mobile device as follows
    Open templates/ja_university/css/layout-mobile.css file
    add new script below
    #ja-slideshow {
    display: none !important;
    Remember to clear cache from Admin area and re-check on mobile device again.
    Let me know if it helps
This topic contains 4 replies, has 2 voices, and was last updated by  Ninja Lead 11 years, 7 months ago.
