August 5, 2016 at 2:35 pm #957301
Exact same issue I am having with latest JA University and JA Medicare & J 3.6.x. I am waiting to upgrade to J 3.6.x for now until I can find a fix.
August 5, 2016 at 3:28 pm #957308Exactly the same for me also. I’m using JA Platon, Joomla 3.6.0 and T3 2.6.0 and in the theme tab I don’t see color names anymore but the path to the theme folder. Now my website only shows default color and i cannot change back. If I try to change theme color all the template is screwed up. To me it seems more a framework issue then a template related issue, but maybe i’m wrong.
August 5, 2016 at 3:39 pm #957309If you have a copy of the Joomla database before you upgraded to J 3.6.x you might want to try to restore to the pre upgrade template ‘params’ field. It can be found in the _template_styles table. Not the best solution but should enable your previous themes to display.
1 user says Thank You to hwy52 for this useful post
August 5, 2016 at 3:43 pm #957315Thank you i’ll try that on a test website. For my production site I’ll wait for Joomlart solution, hoping it will come soon!
August 5, 2016 at 10:29 pm #957367This is the same problem i am having
August 6, 2016 at 9:42 am #957474ok, thank you, i will try…
August 8, 2016 at 6:49 am #957806Hi,
i tried to restore the params field in the template_style table from the previous db but the result is the same, it doersn’t work, The content of params field is the same in the two db.
Any solutions?Thank you
August 8, 2016 at 4:43 pm #957990Same for me, i tried to restore the params field in the template_style table from a working backup of the database but it doesn’t work. If I change theme nothing happens. If I set development mode "on" then the template is messed up like css styling was missing.
- November 2014
- 3854 times in 3563 posts
August 9, 2016 at 3:09 am #9581502 users say Thank You to Ninja Lead for this useful post
This topic contains 10 replies, has 5 voices, and was last updated by hwy52 8 years, 3 months ago.
The topic ‘Problem with theme colors in T3 framework’ is closed to new replies.
