  • Anonymous Inactive
    #1039532
    joomla 3,7,2
    VM 3,22
    http://www.prodajacipela.com
    you can see on homepage latest products without images in thumbs.
    And here:
    http://www.prodajacipela.com/index.php/homepage/mu%C5%A1ka-obu%C4%87a/papu%C4%8De/mubb-klompa-1-detail
    I updated to latest VM, VM AIO and tcpdf – 3.22
    I also updated T3 blank template and T3 system plugin, but many extensions are displayed wrong.
    So i return site to previos state, from backup (right now, everything is updated, except T3)
    I post topic on vmart forum, they said:
    "It is your template.. get your templater to update his work to be compatible with the latest VM3"
    How can i fix thumbs to show?
    Anonymous Moderator
    #1039556
    Reviver template is not a JoomlArt template. It was simply built with our open-source T3 framework.
    It’s best that you contact Reviver’s creator for support on the template issues.
This topic contains 1 reply, has 2 voices, and was last updated by Anonymous 7 years, 5 months ago.
